Some mathematical facts about optimal cache replacement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Architecture and Code Optimization Année : 2016
This paper exposes and proves some mathematical facts about optimal cache replacement that were previously unknown or not proved rigorously. An explicit formula is obtained, giving OPT hits and misses as a function of past references. Several mathematical facts are derived from this formula, including a proof that OPT miss curves are always convex, and a new algorithm called OPT tokens, for reasoning about optimal replacement.
halopt.pdf (365.43 Ko) Télécharger le fichier
HiPEAC2017.pdf (435.43 Ko) Télécharger le fichier
Format : Présentation
hal-01411156 , version 1 (07-12-2016)
hal-01411156 , version 2 (27-01-2017)
Pierre Michaud. Some mathematical facts about optimal cache replacement. ACM Transactions on Architecture and Code Optimization, 2016, 13 (4), ⟨10.1145/3017992⟩. ⟨hal-01411156v2⟩
799 Consultations
1465 Téléchargements
