Blind I/Q Imbalance Compensation for M-QAM Optical Coherent Systems based on Pseudo-rotation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses the problem of In-phase/Quadrature (I/Q) imbalance sensitivity of communication systems when it occurs at both Transmitter (TX) and Receiver (RX) sides of an optical coherent system. A novel blind technique is proposed based on the pseudo-rotation of the M-QAM constellation. The pseudo-rotation based compensator is a generic approach, because it does not depend on the modulation order and the level of imbalance. To implement the proposed compensation in practical systems, two algorithms are proposed: Recursive Pseudo-Rotation (RPR) that achieves the performance of the ideal compensator and LRPR, a Low complexity version of RPR. Monte Carlo simulation results show that the proposed compensator outperforms state-of-the-art algorithms for an Additive White Gaussian Noise (AWGN) and the complexity/performance trade-off is also discussed. The efficiency of the proposed method is experimentally validated with a 10 Gbaud QPSK optical system showing its operation in the presence of Inter-Symbol Interference (ISI).
Globecom_paperIQ.pdf (738.64 Ko) Télécharger le fichier
hal-01412788 , version 1 (08-12-2016)
Ti Nguyen-Ti, Matthieu Gautier, Pascal Scalart, Olivier Berder, Trung Hien Nguyen, et al.. Blind I/Q Imbalance Compensation for M-QAM Optical Coherent Systems based on Pseudo-rotation. 59th IEEE Global Communications Conference (IEEE GLOBECOM 2016), Dec 2016, Washington, United States. ⟨10.1109/GLOCOM.2016.7841633⟩. ⟨hal-01412788⟩
365 Consultations
735 Téléchargements
