Stabilization of LTI systems by relay feedback with perturbed measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper investigates the stabilization of Linear Time Invariant (LTI) systems by relay feedback. Generally the states measurements are subject to perturbations and noises. However, their effect is often ignored in the design of relay feedback. Here a state-dependent switching law is designed in a robust manner, while taking into account the perturbed states. The stability analysis of the closed loop system leads to qualitative conditions. Then, an LMI reformulation of the stability conditions is proposed to allow a numerical implementation of the results. Computer simulations show the efficiency of the developed method over a numerical example.
ACC2016.pdf (246.42 Ko) Télécharger le fichier
hal-01415039 , version 1 (23-01-2018)
Zohra Kader, Christophe Fiter, Laurentiu Hetel, Lotfi Belkoura. Stabilization of LTI systems by relay feedback with perturbed measurements. ACC 2016 - American Control Conference, Jul 2016, Boston, United States. pp.5169-5174, ⟨10.1109/ACC.2016.7526479⟩. ⟨hal-01415039⟩
217 Consultations
144 Téléchargements
