Lightweight Practical Private One-Way Anonymous Messaging - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2015
Anirban Basu
  • Function : Author
  • PersonId : 990570
Juan Camilo Corena
  • Function : Author
  • PersonId : 990572
Jon Crowcroft
  • Function : Author
  • PersonId : 831885
Shinsaku Kiyomoto
  • Function : Author
  • PersonId : 990575
Stephen Marsh
  • Function : Author
  • PersonId : 990565
Toru Nakamura
  • Function : Author
  • PersonId : 996032
Opinions from people, evident in surveys and microblogging, for instance, may have bias or low user participation due to legitimate concerns about privacy and anonymity. To provide sender (the participant) anonymity, the identity of the message sender must be hidden from the message recipient (the opinion collector) and the contents of the actual message hidden from any intermediate actors (such as, routers) that may be responsible for relaying the message. We propose a novel one-way message routing scheme based on probabilistic forwarding that guarantees message privacy and sender anonymity through cryptographic means; utilising an additively homomorphic public-key cryptosystem along with a symmetric cipher. Our scheme involves intermediate relays and can work with either a centralised or a decentralised registry that helps with connecting the relays to each other. In addition to theoretical analysis, we demonstrate a real-world prototype built with HTML5 technologies and deployed on a public cloud environment. The prototype allows anonymous messaging over HTTP(S), and has been run inside HTML5 browsers on mobile application environments with no configurations at the network level. While we leave constructing the reverse path as future work, the proposal contained in this paper complete and has practical applications in anonymous surveys and microblogging.
337890_1_En_6_Chapter.pdf (429.19 Ko) Télécharger le fichier
Dates and versions
hal-01416208 , version 1 (14-12-2016)
Attribution
Identifiers
Cite
Anirban Basu, Juan Camilo Corena, Jaideep Vaidya, Jon Crowcroft, Shinsaku Kiyomoto, et al.. Lightweight Practical Private One-Way Anonymous Messaging. 9th IFIP International Conference on Trust Management (TM), May 2015, Hamburg, Germany. pp.76-91, ⟨10.1007/978-3-319-18491-3_6⟩. ⟨hal-01416208⟩
120 View
118 Download
Share
