Towards adaptive autosar : a system-level approach
The automotive industry has recently agreed upon the embedded software standard AUTOSAR, whichstructures an application into reusable components that can be deployed according to a given configuration. However, this configuration is fixed at design-time, with no support for dynamically adding, migrating and/or removing components to adapt the system at runtime. In this paper, we present the design and implementation of ASLA (Adaptive System-Level in AUTOSAR) a framework that provides runtime adaptation to AUTOSAR. We believe that our approach opens up new functionalities for vehiclesoftware platforms and can be leveraged in therecent initiative Adaptive AUTOSAR.
