Towards adaptive autosar : a system-level approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Amel Belaggoun
  • Fonction : Auteur
  • PersonId : 996138
The automotive industry has recently agreed upon the embedded software standard AUTOSAR, whichstructures an application into reusable components that can be deployed according to a given configuration. However, this configuration is fixed at design-time, with no support for dynamically adding, migrating and/or removing components to adapt the system at runtime. In this paper, we present the design and implementation of ASLA (Adaptive System-Level in AUTOSAR) a framework that provides runtime adaptation to AUTOSAR. We believe that our approach opens up new functionalities for vehiclesoftware platforms and can be leveraged in therecent initiative Adaptive AUTOSAR.
F2016-VESE-003BELAGGOUNAmel.pdf (799.2 Ko) Télécharger le fichier
hal-01416879 , version 1 (14-12-2016)
  • HAL Id : hal-01416879 , version 1
Amel Belaggoun, Valerie Issarny. Towards adaptive autosar : a system-level approach. FISITA 2016 World Automotive Congress, Sep 2016, Busan, South Korea. ⟨hal-01416879⟩
Collections
INRIA INRIA2
452 Consultations
1181 Téléchargements
