Using Natural Language Feedback in a Neuro-inspired Integrated Multimodal Robotic Architecture
In this paper we present a multi-modal human robot interaction architecture which is able to combine information coming from different sensory inputs, and can generate feedback for the user which helps to teach him/her implicitly how to interact with the robot. The system combines vision, speech and language with inference and feedback. The system environment consists of a Nao robot which has to learn objects situated on a table only by understanding absolute and relative object locations uttered by the user and afterwards points on a desired object to show what it has learned. The results of a user study and performance test show the usefulness of the feedback produced by the system and also justify the usage of the system in a real-world applications, as its classification accuracy of multi-modal input is around 80.8%. In the experiments, the system was able to detect inconsistent input coming from different sensory modules in all cases and could generate useful feedback for the user from this information.
