An Improved Method for Image Retrieval Based on Color and Texture Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jun Yue
  • Fonction : Auteur
  • PersonId : 996755
Zhenbo Li
  • Fonction : Auteur
With the development of technology and Internet,people need more and more information.The carrier of information is also changed from the original text into the current image, video, etc. Image retrieval plays an increasingly important role in the field of study. This paper is a study of image retrieval based on color and texture features, the main algorithms include color histogram,color moment,gray level co-occurrence matrix(GLCM) and Tamura texture features,etc.Then it made further improvements that combined color histogram and Tamura texture features method (we made Tamura texture retriveal again based on color histogram firstly) based on search results.Experimental results demonstrate that the rates of retriveal by comprehensive approach is higher than using a single method.
978-3-319-19620-6_80_Chapter.pdf (852.23 Ko) Télécharger le fichier
hal-01420292 , version 1 (20-12-2016)
Paternité
Jun Yue, Chen Li, Zhenbo Li. An Improved Method for Image Retrieval Based on Color and Texture Features. 8th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2014, Beijing, China. pp.739-752, ⟨10.1007/978-3-319-19620-6_80⟩. ⟨hal-01420292⟩
82 Consultations
197 Téléchargements
