A forecasting algorithm for latency compensation in indirect human-computer interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Human-computer interactions are greatly affected by the latency between the human input and the system visual response. The compensation of this latency is an important problem for the HCI (human-computer interaction) community. In this work, a simple forecasting algorithm is developed for latency compensation in indirect interaction using a mouse, based on numerical differentiation. Several differentiators are compared, including a novel algebraic version. An optimized procedure is developed for tuning the parameters of the algorithm. The efficiency is demonstrated on real data, measured with a 1 ms sampling time.
UECRP_ECC_2016.pdf (503.75 Ko) Télécharger le fichier
hal-01420653 , version 1 (24-01-2017)
  • HAL Id : hal-01420653 , version 1
Rosane Ushirobira, Denis Efimov, Géry Casiez, Nicolas Roussel, Wilfrid Perruquetti. A forecasting algorithm for latency compensation in indirect human-computer interactions. In proceedings of ECC'16, the 15th annual European Control Conference, Jun 2016, Aalborg, Denmark. pp.6. ⟨hal-01420653⟩
325 Consultations
481 Téléchargements
