How Fuzzy FCA and Pattern Structures are connected? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
FCA is a mathematical formalism having many applications in data mining and knowledge discovery. Originally it deals with binary data tables. However, there is a number of extensions that enrich standard FCA. In this paper we consider two important extensions: fuzzy FCA and pattern structures, and discuss the relation between them. In particular we introduce a scaling procedure that enables representing a fuzzy context as a pattern structure.
fca4ai16.pdf (281.34 Ko) Télécharger le fichier
hal-01420997 , version 1 (21-12-2016)
  • HAL Id : hal-01420997 , version 1
Aleksey Buzmakov, Amedeo Napoli. How Fuzzy FCA and Pattern Structures are connected?. 5th Workshop "What can FCA do for Artificial Intelligence?" (FCA4AI'2016), Aug 2016, The Hague, Netherlands. ⟨hal-01420997⟩
259 Consultations
165 Téléchargements
