Multilingual Projection for Parsing Truly Low-Resource Languageš - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions of the Association for Computational Linguistics Année : 2016
We propose a novel approach to cross-lingual part-of-speech tagging and dependency parsing for truly low-resource languages. Our annotation projection-based approach yields tagging and parsing models for over 100 languages. All that is needed are freely available parallel texts, and taggers and parsers for resource-rich languages. The empirical evaluation across 30 test languages shows that our method consistently provides top-level accuracies , close to established upper bounds, and outperforms several competitive baselines.
Q16-1022.pdf (305.42 Ko) Télécharger le fichier
hal-01426754 , version 1 (04-01-2017)
  • HAL Id : hal-01426754 , version 1
Zeljko Agic, Anders Johannsen, Barbara Plank, Héctor Martínez Alonso, Natalie Schluter, et al.. Multilingual Projection for Parsing Truly Low-Resource Languageš. Transactions of the Association for Computational Linguistics, 2016. ⟨hal-01426754⟩
126 Consultations
368 Téléchargements
