Security Challenges of Additive Manufacturing with Metals and Alloys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cyber-physical systems are under constant and increasing attacks as components of the critical infrastructure. Additive manufacturing systems are a new class of cyber-physical systems that produce threedimensional objects layer by layer. Agencies and companies such as NASA, the European Space Agency, General Electric and SpaceX have explored a broad range of application areas for additive manufacturing, including creating functional parts of safety-critical systems such as jet engines. The range of application areas and dependence on computerization makes additive manufacturing an attractive target for attackers.This chapter focuses on attacks that seek to change the physical properties of additive-manufactured components. Such attacks can weaken, damage or destroy manufactured components and, in scenarios where weak or damaged components are used in safety-critical systems, potentially endanger human lives. Attacks intended to damage additive manufacturing equipment and additive manufacturing environments are also discussed.
978-3-319-26567-4_11_Chapter.pdf (243.03 Ko) Télécharger le fichier
hal-01431001 , version 1 (10-01-2017)
Paternité
Mark Yampolskiy, Lena Schutzle, Uday Vaidya, Alec Yasinsac. Security Challenges of Additive Manufacturing with Metals and Alloys. 9th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2015, Arlington, VA, United States. pp.169-183, ⟨10.1007/978-3-319-26567-4_11⟩. ⟨hal-01431001⟩
361 Consultations
777 Téléchargements
