Webservice-Ready Configurable Devices for Intelligent Manufacturing Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jiří Faist
  • Fonction : Auteur
  • PersonId : 997866
Milan Štětina
  • Fonction : Auteur
  • PersonId : 997867
This paper takes closer look at inner structure of an eScop RTU device, a highly configurable PLC-like embedded device developed in Node.js environment for low level physical layer of Intelligent Manufacturing Systems.
346973_1_En_55_Chapter.pdf (313.01 Ko) Télécharger le fichier
hal-01431135 , version 1 (10-01-2017)
Paternité
Jiří Faist, Milan Štětina. Webservice-Ready Configurable Devices for Intelligent Manufacturing Systems. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.476-483, ⟨10.1007/978-3-319-22759-7_55⟩. ⟨hal-01431135⟩
32 Consultations
77 Téléchargements
