Technology Evaluation Using Modified Integrated Method of Technical Project Assessment
This paper proposes a method of evaluation of novel technologies, like ontology engineering based solutions, in conditions when a paradigm based on the balance of economy, society and environment is adopted. The evaluation applies a holistic approach. The proposed method is based on the idea of integrated efficiency evaluation of technical and organizational projects. Its key elements are the assessment measures and the management control procedures.
Informatique [cs]
