A Proposal of Value Co-creative Production with IoT-Based Thinking Factory Concept for Tailor-Made Rubber Products - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Toshiya Kaihara
  • Fonction : Auteur
  • PersonId : 992737
Daisuke Kokuryo
  • Fonction : Auteur
Swee Kuik
  • Fonction : Auteur
Production companies are required to notice the importance of the paradigm shift from “use value” into “value in use” about their products and services. Value co-creative activity between the producers and consumers is essential to realise the paradigm shift in practical business case. The IoT(Internet of Things) is a powerful infrastructure to digitalise and increase the integration of vertical and horizontal value chains in the business process. We propose a value co-creative production system model under IoT environment with an innovative “Thinking factory” concept. Our current target is the rubber industry which is required to provide tailor-made products as human-machine delicate interface.
346973_1_En_8_Chapter.pdf (2.14 Mo) Télécharger le fichier
hal-01431157 , version 1 (10-01-2017)
Paternité
Toshiya Kaihara, Daisuke Kokuryo, Swee Kuik. A Proposal of Value Co-creative Production with IoT-Based Thinking Factory Concept for Tailor-Made Rubber Products. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.67-73, ⟨10.1007/978-3-319-22759-7_8⟩. ⟨hal-01431157⟩
75 Consultations
314 Téléchargements
