Benchmarking Wireless Protocols for Feasibility in Supporting Crowdsourced Mobile Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
João Rodrigues
  • Fonction : Auteur
  • PersonId : 998214
Joaquim Silva
  • Fonction : Auteur
  • PersonId : 998215
Rolando Martins
  • Fonction : Auteur
  • PersonId : 998216
Luís Lopes
  • Fonction : Auteur
  • PersonId : 998217
Utsav Drolia
  • Fonction : Auteur
  • PersonId : 998218
Priya Narasimhan
  • Fonction : Auteur
  • PersonId : 998219
Fernando Silva
  • Fonction : Auteur
  • PersonId : 998220
Recent advances in mobile device technology have triggered research on using their aggregate computational and/or storage resources to form edge-clouds. Whilst traditionally viewed as simple clients, smartphones and tablets today have hardware resources that allow more sophisticated software to be installed, and can be used as thick clients or even thin servers. Simultaneously, new standards and protocols, such as Wi-Fi Direct and Wi-Fi TDLS (Tunneled Direct Link Setup), have been established that allow mobile devices to talk directly with each other, as opposed to over the Internet or across Wi-Fi access points. This can, potentially, lead to ubiquitous, low-latency, device-to-device (D2D) communication. In this paper, we study whether D2D protocols can support mobile-edge clouds by benchmarking different protocols and configurations for a specific application. The results show that decentralized device-to-device techniques can be used to efficiently disseminate multi- media contents while diminishing contention in the wireless infrastructure, allowing for up to 65 % traffic reduction at the access points.
416479_1_En_8_Chapter.pdf (469.33 Ko) Télécharger le fichier
hal-01434803 , version 1 (13-01-2017)
Paternité
João Rodrigues, Joaquim Silva, Rolando Martins, Luís Lopes, Utsav Drolia, et al.. Benchmarking Wireless Protocols for Feasibility in Supporting Crowdsourced Mobile Computing. 16th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2016, Heraklion, Crete, Greece. pp.96-108, ⟨10.1007/978-3-319-39577-7_8⟩. ⟨hal-01434803⟩
72 Consultations
136 Téléchargements
