BFT-Dep: Automatic Deployment of Byzantine Fault-Tolerant Services in PaaS Cloud - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cloud computing has been a massive trend over the recent years and eased the deployment of scalable distributed applications. While initially renting out virtual machines was the predominant form of cloud computing, nowadays Platform as a Service (PaaS) solutions are emerging. The main advantages of the latter are a faster and easier application deployment as well as built-in support for horizontal scalability. However, when it comes to services with more demanding dependability requirements, currently provided deployment mechanisms quickly become insufficient, forcing cloud customers to fall back into manual, self-made strategies.In this paper, we present BFT-Dep, a framework for deploying Byzantine fault-tolerant (BFT) services in a PaaS cloud automatically. BFT-Dep leverages the existing PaaS functionality to address specific deployment requirements and provides tailored support to set up and manage replicated services. It flexibly integrates BFT protocols as an independent service layer, thereby alleviating the complexity that the deployment of such systems entails. An initial prototype of BFT-Dep has been implemented on top of the open-source PaaS platform OpenShift and a first evaluation shows its practicability.
416479_1_En_9_Chapter.pdf (287.86 Ko) Télécharger le fichier
hal-01434804 , version 1 (13-01-2017)
Paternité
Bijun Li, Rüdiger Kapitza. BFT-Dep: Automatic Deployment of Byzantine Fault-Tolerant Services in PaaS Cloud. 16th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2016, Heraklion, Crete, Greece. pp.109-114, ⟨10.1007/978-3-319-39577-7_9⟩. ⟨hal-01434804⟩
109 Consultations
119 Téléchargements
