QoS Multi-tree Based Routing Protocol for Inter-mesh Infrastructure Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hajer Bargaoui
  • Fonction : Auteur
  • PersonId : 961313
Nader Mbarek
Olivier Togni
Mounir Frikha
  • Fonction : Auteur
  • PersonId : 998244
Quality of service (QoS) in wireless mesh networks (WMN) is an active area of research, which is driven by the increasing demand for real-time and multimedia applications, such as VoIP (Voice over IP) and VoD (Video on Demand). In this paper, we propose a QoS multi-tree based routing protocol for wireless mesh environments, named Inter-Mesh Infrastructure Proactive Routing (IMPR). It is a proactive multi-tree routing protocol enabling QoS guarantee for communications from/towards the Internet network through the Mesh Gateway (MG) of the mesh infrastructure. We describe and analyze the simulation results of different scenarios conducted on the network simulator ns-3 to demonstrate the effectiveness of our IMPR routing protocol in forwarding real-time applications with QoS guarantee.
417220_1_En_16_Chapter.pdf (256.98 Ko) Télécharger le fichier
hal-01434852 , version 1 (13-01-2017)
Paternité
Hajer Bargaoui, Nader Mbarek, Olivier Togni, Mounir Frikha. QoS Multi-tree Based Routing Protocol for Inter-mesh Infrastructure Communications. 14th International Conference on Wired/Wireless Internet Communication (WWIC), May 2016, Thessaloniki, Greece. pp.199-211, ⟨10.1007/978-3-319-33936-8_16⟩. ⟨hal-01434852⟩
194 Consultations
144 Téléchargements
