Shrinking and Expanding Cellular Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Augusto Modanese
  • Fonction : Auteur
  • PersonId : 998305
Thomas Worsch
  • Fonction : Auteur
  • PersonId : 884121
Inspired by shrinking cellular automata (SCA), we investigate another variant of the classical one-dimensional cellular automaton: the shrinking and expanding cellular automaton (SXCA). In addition to the capability to delete some cells as in SCA, an SXCA can also create new cells between already existing ones. It is shown that there are reasonably close (polynomial) relations between the time complexity of SXCA and the space and time complexity of Turing machines and alternating Turing machines respectively. As a consequence the class of problems decidable in polynomial time by SXCA coincides with PSPACE.
395687_1_En_13_Chapter.pdf (273.62 Ko) Télécharger le fichier
hal-01435026 , version 1 (13-01-2017)
Paternité
Augusto Modanese, Thomas Worsch. Shrinking and Expanding Cellular Automata. 22th International Workshop on Cellular Automata and Discrete Complex Systems (AUTOMATA), Jun 2016, Zurich, Switzerland. pp.159-169, ⟨10.1007/978-3-319-39300-1_13⟩. ⟨hal-01435026⟩
138 Consultations
95 Téléchargements
