Particle approximation of a constrained model for traffic flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Differential Equations and Applications Année : 2017
We rigorously prove the convergence of the micro-macro limit for particle approximations of the Aw-Rascle-Zhang equations with a maximal density constraint. The lack of BV bounds on the density variable is supplied by a compensated compactness argument.
BerthelinGoatin.pdf (276.15 Ko) Télécharger le fichier
hal-01437867 , version 1 (17-01-2017)
  • HAL Id : hal-01437867 , version 1
Florent Berthelin, Paola Goatin. Particle approximation of a constrained model for traffic flow. Nonlinear Differential Equations and Applications, 2017, 24 (5), pp.24-55. ⟨hal-01437867⟩
370 Consultations
202 Téléchargements
