Improving Collaboration Between Large and Small Enterprises Using Networked Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Isabel Matranga
  • Fonction : Auteur
  • PersonId : 998511
Vincenzo Savarino
  • Fonction : Auteur
  • PersonId : 998512
Karol Furdik
  • Fonction : Auteur
  • PersonId : 998513
Martin Tomášek
  • Fonction : Auteur
  • PersonId : 998514
Collaboration between large and small & medium-sized enterprises is still not adequately supported by current groupware solutions. In this paper, we present a novel approach that addresses the challenges of inter-enterprise collaboration. Key elements of our approach are: interoperability to legacy applications to retain current working styles, basic services for sharing and management of shared collaboration spaces, use of email for collaboration especially on the SME’s side, information extraction to enable semantic search in inter-enterprise collaborations and automatic tagging of documents, and integration of business process models. We evaluated the approach on three application cases in the workplace: new product development, software development supply chain, and supply chain collaboration between SMEs and LEs. Our results suggest that the implemented services are beneficial in typical cooperation situations between enterprises.
370605_1_En_18_Chapter.pdf (177.8 Ko) Télécharger le fichier
hal-01437888 , version 1 (17-01-2017)
Paternité
Wolfgang Gräther, Isabel Matranga, Vincenzo Savarino, Karol Furdik, Martin Tomášek. Improving Collaboration Between Large and Small Enterprises Using Networked Services. 16th Working Conference on Virtual Enterprises (PROVE), Oct 2015, Albi, France. pp.201-208, ⟨10.1007/978-3-319-24141-8_18⟩. ⟨hal-01437888⟩
178 Consultations
160 Téléchargements
