GA-ANN Short-Term Electricity Load Forecasting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a methodology for short-term load forecasting based on genetic algorithm feature selection and artificial neural network modeling. A feedforward artificial neural network is used to model the 24-h ahead load based on past consumption, weather and stock index data. A genetic algorithm is used in order to find the best subset of variables for modeling. Three datasets of different geographical locations, encompassing areas of different dimensions with distinct load profiles are used in order to evaluate the methodology. The developed approach was found to generate models achieving a minimum mean average percentage error under 2 %. The feature selection algorithm was able to significantly reduce the number of used features and increase the accuracy of the models.
419233_1_En_45_Chapter.pdf (408.37 Ko) Télécharger le fichier
hal-01438275 , version 1 (17-01-2017)
Paternité
Joaquim L. Viegas, Susana M. Vieira, Rui Melício, Victor F. Mendes, João C. Sousa. GA-ANN Short-Term Electricity Load Forecasting. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.485-493, ⟨10.1007/978-3-319-31165-4_45⟩. ⟨hal-01438275⟩
70 Consultations
66 Téléchargements
