A General Model Transformation Methodology to Serve Enterprise Interoperability Data Sharing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tiexin Wang
  • Fonction : Auteur
  • PersonId : 998548
Sébastien Truptil
Frederick Benaben
Interoperability, as one of the key competition factors for modern enterprises, describes the ability to establish partnership activities in an environment of unstable market. In some terms, interoperability determines the future of enterprises; so, improving enterprises’ interoperability turns to be a research focus. “Sharing data among heterogeneous partners” is one of the most basic common interoperability problems, which requires a general methodology to serve. Model transformation, which plays a key role in model-driven engineering, provides a possible solution to data sharing problem. A general model transformation methodology, which could shield traditional model transformation practices’ weaknesses: low reusability, contains repetitive tasks, involves huge manual effort, etc., is an ideal solution to data sharing problem. This paper presents a general model transformation methodology “combining semantic check measurement and syntactic check measurement into refined model transformation processes” and the mechanism of using it to serve interoperability’s data sharing issue.
338001_1_En_2_Chapter.pdf (699.2 Ko) Télécharger le fichier
hal-01438402 , version 1 (17-01-2017)
Paternité
Tiexin Wang, Sébastien Truptil, Frederick Benaben. A General Model Transformation Methodology to Serve Enterprise Interoperability Data Sharing Problem. 6th International IFIP Working Conference on Enterprise Interoperability (IWEI), May 2015, Nîmes, France. pp.16-29, ⟨10.1007/978-3-662-47157-9_2⟩. ⟨hal-01438402⟩
391 Consultations
139 Téléchargements
