Analyzing Attack Strategies Through Anti-goal Refinement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Analyzing security from an attacker’s perspective has been accepted as an effective approach for dealing with security requirements for complex systems. However, there is no systematic approach for constructing attack scenarios. As a result, the completeness of the derived attack scenarios is subject to the expertise of analysts. In this paper, we propose a systematic process for identifying attack scenarios to support security analysis, founded on anti-goal refinement. In particular, we examine three real attack scenarios in order to understand attack strategies that have been applied in reality. Based on our examination, we propose a comprehensive anti-goal refinement framework, which consists of five anti-goal refinement patterns and an analysis process for using the patterns as part of security design. Finally, we evaluate the proposed anti-goal refinement framework by applying it to a credit card theft scenario.
978-3-319-25897-3_6_Chapter.pdf (322.21 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01442299 , version 1 (20-01-2017)
Tong Li, Jennifer Horkoffi, Elda Pajai, Kristian Beckers, John Mylopoulos. Analyzing Attack Strategies Through Anti-goal Refinement. 8th Practice of Enterprise Modelling (P0EM), Nov 2015, Valencia, Spain. pp.75-90, ⟨10.1007/978-3-319-25897-3_6⟩. ⟨hal-01442299⟩
83 Consultations
94 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
