Designing of Hierarchical Structures for Binary Comparators on FPGA/SoC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Valery Salauyou
  • Fonction : Auteur
  • PersonId : 999187
Marek Gruszewski
  • Fonction : Auteur
  • PersonId : 999188
The article considers the general synthesis technique of hierarchical tree structures on FPGA/SoC for binary comparators. Designing of first level comparators is given. The best hierarchical comparator structure for the specific FPGA/SoC family is found empirically by experimental researches. The offered method allows reducing an area from 5.3% to 43.0%, and for high bitwidth comparators (with an input word length 1024) by 2.225 times. In the conclusion additional opportunities of the offered method are marked, and main directions of further researches are presented.
978-3-319-24369-6_32_Chapter.pdf (313.88 Ko) Télécharger le fichier
hal-01444482 , version 1 (24-01-2017)
Paternité
Valery Salauyou, Marek Gruszewski. Designing of Hierarchical Structures for Binary Comparators on FPGA/SoC. 14th Computer Information Systems and Industrial Management (CISIM), Sep 2015, Warsaw, Poland. pp.386-396, ⟨10.1007/978-3-319-24369-6_32⟩. ⟨hal-01444482⟩
56 Consultations
1186 Téléchargements
