Optical Music Recognition: Standard and Cost-Sensitive Learning with Imbalanced Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The article is focused on a particular aspect of classification, namely the issue of class imbalance. Imbalanced data adversely affects the recognition ability and requires proper classifier’s construction. In this work we present a case of music notation as an example of imbalanced data. Three classification algorithms - random forest, standard SVM and cost-sensitive SVM are described and tested. Feature selection based on random forest feature importance was used. Also, feature dimension reduction using PCA was studied.
978-3-319-24369-6_51_Chapter.pdf (295.59 Ko) Télécharger le fichier
hal-01444503 , version 1 (24-01-2017)
Paternité
Wojciech Lesinski, Agnieszka Jastrzebska. Optical Music Recognition: Standard and Cost-Sensitive Learning with Imbalanced Data. 14th Computer Information Systems and Industrial Management (CISIM), Sep 2015, Warsaw, Poland. pp.601-612, ⟨10.1007/978-3-319-24369-6_51⟩. ⟨hal-01444503⟩
90 Consultations
128 Téléchargements
