Plane Geodesic Spanning Trees, Hamiltonian Cycles, and Perfect Matchings in a Simple Polygon - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2016
Ahmad Biniaz
  • Function : Author
  • PersonId : 999379
Michiel Smid
  • Function : Author
Let S be a finite set of points in the interior of a simple polygon P. A geodesic graph, $G_P(S,E)$, is a graph with vertex set S and edge set E such that each edge $(a,b)\in E$ is the shortest path between a and b inside P. $G_P$ is said to be plane if the edges in E do not cross. If the points in S are colored, then $G_P$ is said to be properly colored provided that, for each edge $(a,b)\in E$, a and b have different colors. In this paper we consider the problem of computing (properly colored) plane geodesic perfect matchings, Hamiltonian cycles, and spanning trees of maximum degree three.
385217_1_En_5_Chapter.pdf (399.9 Ko) Télécharger le fichier
Dates and versions
hal-01446264 , version 1 (25-01-2017)
Attribution
Identifiers
Cite
Ahmad Biniaz, Prosenjit Bose, Anil Maheshwari, Michiel Smid. Plane Geodesic Spanning Trees, Hamiltonian Cycles, and Perfect Matchings in a Simple Polygon. 1st International Conference on Theoretical Computer Science (TTCS), Aug 2015, Tehran, Iran. pp.56-71, ⟨10.1007/978-3-319-28678-5_5⟩. ⟨hal-01446264⟩
36 View
131 Download
Share
