HJB equations in infinite dimension and optimal control of stochastic evolution equations via generalized Fukushima decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2017
A stochastic optimal control problem driven by an abstract evolution equation in a separable Hilbert space is considered. Thanks to the identification of the mild solution of the state equation as $\nu$-weak Dirichlet process, the value processes is proved to be a real weak Dirichlet process. The uniqueness of the corresponding decomposition is used to prove a verification theorem. Through that technique several of the required assumptions are milder than those employed in previous contributions about non-regular solutions of Hamilton-Jacobi-Bellman equations.
FabbriRussoAugust2017SFB.pdf (294.39 Ko) Télécharger le fichier
hal-01447562 , version 1 (27-01-2017)
hal-01447562 , version 2 (17-08-2017)
Giorgio Fabbri, Francesco Russo. HJB equations in infinite dimension and optimal control of stochastic evolution equations via generalized Fukushima decomposition. SIAM Journal on Control and Optimization, 2017, 55 (6), pp.4072-4091. ⟨10.1137/17M1113801⟩. ⟨hal-01447562v2⟩
343 Consultations
530 Téléchargements
