HJB equations in infinite dimension and optimal control of stochastic evolution equations via generalized Fukushima decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
A stochastic optimal control problem driven by an abstract evolution equation in a separable Hilbert space is considered. Thanks to the identification of the mild solution of the state equation as $\nu$-weak Dirichlet process, the value processes is proved to be a real weak Dirichlet process. The uniqueness of the corresponding decomposition is used to prove a verification theorem. Through that technique several of the required assumptions are milder than those employed in previous contributions about non-regular solutions of Hamilton-Jacobi-Bellman equations.
controllo25January2017ToSubmit.pdf (241.91 Ko) Télécharger le fichier
hal-01447562 , version 1 (27-01-2017)
hal-01447562 , version 2 (17-08-2017)
Giorgio Fabbri, Francesco Russo. HJB equations in infinite dimension and optimal control of stochastic evolution equations via generalized Fukushima decomposition. 2017. ⟨hal-01447562v1⟩
343 Consultations
532 Téléchargements
