Long-time homogenization and asymptotic ballistic transport of classical waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Scientifiques de l'École Normale Supérieure Année : 2017
Consider an elliptic operator in divergence form with symmetric coefficients. If the diffusion coefficients are periodic, the Bloch theorem allows one to diagonalize the elliptic operator, which is key to the spectral properties of the elliptic operator and the usual starting point for the study of its long-time homogenization. When the coefficients are not periodic (say, quasi-periodic, almost periodic, or random with decaying correlations at infinity), the Bloch theorem does not hold and both the spectral properties and the long-time behavior of the associated operator are unclear. At low frequencies, we may however consider a formal Taylor expansion of Bloch waves (whether they exist or not) based on correctors in elliptic homogenization. The associated Taylor-Bloch waves diagonalize the elliptic operator up to an error term (an ``eigendefect''), which we express with the help of a new family of extended correctors. We use the Taylor-Bloch waves with eigendefects to quantify the transport properties and homogenization error over large times for the wave equation in terms of the spatial growth of these extended correctors. On the one hand, this quantifies the validity of homogenization over large times (both for the standard homogenized equation and higher-order versions). On the other hand, this allows us to prove asymptotic ballistic transport of classical waves at low energies for almost periodic and random operators.
BenoitGloria.pdf (446.47 Ko) Télécharger le fichier
hal-01449353 , version 1 (30-01-2017)
hal-01449353 , version 2 (14-11-2017)
hal-01449353 , version 3 (18-09-2018)
Antoine Benoit, Antoine Gloria. Long-time homogenization and asymptotic ballistic transport of classical waves. Annales Scientifiques de l'École Normale Supérieure, In press. ⟨hal-01449353v2⟩
488 Consultations
305 Téléchargements
