Cyber-Physical Production Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today a high adherence to delivery dates is the main logistic target for manufacturing companies. To control the increasing complexity of production planning and control manufacturing companies use IT systems. However, the applied IT systems often do not provide a reliable forecast of delivery dates and thus affect the required adherence to delivery dates. The paper describes a cyber-physical approach to optimize the production planning and control towards a reliable detailed planning. Therefore, it is necessary to determine the deviations between the production schedule of the IT system and the production processes in reality. With the knowledge of the revealed deviations and their causes the process of production planning can be adjusted towards a more dependable high resolution production planning and control.
978-3-642-41263-9_59_Chapter.pdf (201.55 Ko) Télécharger le fichier
hal-01449758 , version 1 (30-01-2017)
Paternité
Guenther Schuh, Till Potente, Christina Thomas, Annika Hauptvogel. Cyber-Physical Production Management. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.477-484, ⟨10.1007/978-3-642-41263-9_59⟩. ⟨hal-01449758⟩
431 Consultations
197 Téléchargements
