Relevance of Kotter’s Model for Change in Successfully Implementing Lean - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shovan Mishra
  • Fonction : Auteur
  • PersonId : 999790
Though lean consists of numerous tools and techniques that are applicable to entire value stream, there are not many guidelines on how to implement lean from the managerial perspective. Lean implementation has succeeded and failed in many different organizations. This paper attempts to map success factors of lean implementation as suggested by some studies with Kotter’s eight steps model for change.
978-3-642-41263-9_67_Chapter.pdf (202.65 Ko) Télécharger le fichier
hal-01449768 , version 1 (30-01-2017)
Paternité
Shovan Mishra. Relevance of Kotter’s Model for Change in Successfully Implementing Lean. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.540-547, ⟨10.1007/978-3-642-41263-9_67⟩. ⟨hal-01449768⟩
109 Consultations
3304 Téléchargements
