Requirements for Servitization in Manufacturing Service Ecosystems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michele Sesana
  • Fonction : Auteur
  • PersonId : 999806
Sergio Gusmeroli
  • Fonction : Auteur
  • PersonId : 999807
As tangible products can be easily copied and customers ask for individual solutions, the European manufacturing industry increasingly bundles their products with associated services to so called “Extended Products” (EP). Missing competencies for this servitization have to be acquired by involving partners from the companies’ environment, the “Manufacturing Service Ecosystem” (MSE). However, traditional manufacturers lack the appropriate models, methods and tools for collaborative innovation, development and provision of EP. This paper presents the results of a requirements analysis of four manufacturing use cases that indicates the need for support in the area of servitization and collaboration in MSE.
978-3-642-41263-9_9_Chapter.pdf (171.82 Ko) Télécharger le fichier
hal-01449777 , version 1 (30-01-2017)
Paternité
Stefan Wiesner, Michele Sesana, Sergio Gusmeroli, Klaus-Dieter Thoben. Requirements for Servitization in Manufacturing Service Ecosystems. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.65-72, ⟨10.1007/978-3-642-41263-9_9⟩. ⟨hal-01449777⟩
223 Consultations
379 Téléchargements
