A Simulation Enabled Procedure for Eco-efficiency Optimization in Production Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Environmental sustainability in manufacturing has been experiencing increasing attention in practice and academia over the last decades. Manufacturing companies strive to improve their eco-efficiency, which is commonly understood as delivering high value products at lower cost and environmental impact. They need tools and methods to translate this strategic goal onto the operational shop floor level. This paper presents a procedure for optimizing the eco-efficiency of production systems, supported by a discrete-event material flow simulation model. Its application is shown in a case with a company from the Swiss consumer goods industry.
978-3-642-41263-9_15_Chapter.pdf (288.59 Ko) Télécharger le fichier
hal-01451746 , version 1 (01-02-2017)
Paternité
Alexander Sproedt, Johannes Plehn, Philipp Hertz. A Simulation Enabled Procedure for Eco-efficiency Optimization in Production Systems. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.118-125, ⟨10.1007/978-3-642-41263-9_15⟩. ⟨hal-01451746⟩
113 Consultations
122 Téléchargements
