Teaching Supply Chain Management: Mixed vs. Pure Strategies in Simulation Based Training - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Avinoam Tzimerman
  • Fonction : Auteur
Yale Herer
  • Fonction : Auteur
Avraham Shtub
  • Fonction : Auteur
We investigate two inter-entity strategies for using SBT by teams—a competitive strategy and a cooperative strategy within the supply chain management domain. We examine how a combination of these inter-entity strategies would work at situations wherein both are used, one following the other. The goal is to investigate from a pedagogical and practical perspective which strategy is the most effective using SBT techniques for business education—pure strategy (strictly cooperative/competitive) or mixed (a combination of both). The results indicate that it is better to teach with mixed strategies when using SBT by teams, than to teach only one (pure) strategy. Moreover, if both strategies are used, then the order of teaching is significant. It is better to start with a competitive strategy and then move to a cooperative strategy rather than the reverse.
978-3-642-41263-9_16_Chapter.pdf (111.17 Ko) Télécharger le fichier
hal-01451747 , version 1 (01-02-2017)
Paternité
Avinoam Tzimerman, Yale Herer, Avraham Shtub. Teaching Supply Chain Management: Mixed vs. Pure Strategies in Simulation Based Training. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.126-133, ⟨10.1007/978-3-642-41263-9_16⟩. ⟨hal-01451747⟩
103 Consultations
266 Téléchargements
