Sustainability Enhancement through Environmental Impacts Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matteo Mario Savino
  • Fonction : Auteur
  • PersonId : 861268
Antonio Mazza
  • Fonction : Auteur
  • PersonId : 953967
The work is aimed to propose an approach toward the evaluation of environmental impacts enhancing sustainability and the process of environmental assessment in an optic of sustainable development. A set of environmental aspects applicable to a firm activity to define the overall environmental impact are selected and processed through a fuzzy approach aimed to reduce subjective judgments. The procedure is based on a vectorial graph allowing to organize data and define a structured data analysis. An action research conducted in a genetic research center is conducted to evaluate the effectiveness of the proposed approach.
978-3-642-41266-0_29_Chapter.pdf (341.67 Ko) Télécharger le fichier
hal-01452118 , version 1 (01-02-2017)
Paternité
Matteo Mario Savino, Antonio Mazza. Sustainability Enhancement through Environmental Impacts Evaluation. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.235-242, ⟨10.1007/978-3-642-41266-0_29⟩. ⟨hal-01452118⟩
91 Consultations
145 Téléchargements
