Supply Chain Interoperability Efforts Missing Key Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christopher Peters
  • Fonction : Auteur
  • PersonId : 1000028
True manufacturing supply chain interoperability—where the assembly, reconfiguration and reconstitution of supply chains are done with minimal effort, time or cost—can dramatically alter the way that business is done today. Much of the existing research on supply chain interoperability focuses on established trading partners. However, we must consider both the sourcing and connecting processes in order to create true, dynamic supplier networks that can be easily assembled, reconfigured or reconstituted. This paper identifies why this is important, presents key challenges and proposes additional research that is needed to fill in the gaps.
978-3-642-41266-0_39_Chapter.pdf (159.35 Ko) Télécharger le fichier
hal-01452129 , version 1 (01-02-2017)
Paternité
Christopher Peters. Supply Chain Interoperability Efforts Missing Key Data. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.318-324, ⟨10.1007/978-3-642-41266-0_39⟩. ⟨hal-01452129⟩
114 Consultations
100 Téléchargements
