Use Case Analysis for Standard Manufacturing Service Capability Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yunsu Lee
  • Fonction : Auteur
  • PersonId : 991715
Boonserm (serm) Kulvatunyou
  • Fonction : Auteur
  • PersonId : 991712
Marko Vujasinovic
  • Fonction : Auteur
  • PersonId : 1000036
Nenad Ivezic
  • Fonction : Auteur
  • PersonId : 991714
Manufacturing enterprises are becoming globally distributed production systems. Rigid supply chains are giving way to dynamic supply networks that are cost-efficient and can respond to change quickly. A key factor in the formation of dynamic supply networks is the communication of manufacturing capabilities – both production capabilities and information processing capabilities. These are collectively referred to as manufacturing service capability (MSC) information. Presently, MSC information is provided using many different, proprietary terminologies and representations. The lack of a standard model impedes communications of MSC information. We propose the development of a standard MSC model to enhance the MSC information communications. This paper motives such development by presenting a use case analysis that illustrates the current and a desirable future state of MSC information communication. The future state, which relies on a standard MSC model can advance the current practice and allow precise and computer-interpretable representation of MSC information.
978-3-642-41266-0_44_Chapter.pdf (166.12 Ko) Télécharger le fichier
hal-01452135 , version 1 (01-02-2017)
Paternité
Yunsu Lee, Boonserm (serm) Kulvatunyou, Marko Vujasinovic, Nenad Ivezic. Use Case Analysis for Standard Manufacturing Service Capability Model. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.361-369, ⟨10.1007/978-3-642-41266-0_44⟩. ⟨hal-01452135⟩
112 Consultations
87 Téléchargements
