Manufacturing Capability Inference and Supplier Classification Based on a Formal Thesaurus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Farhad Ameri
  • Fonction : Auteur
  • PersonId : 944847
Stan Thornhill
  • Fonction : Auteur
  • PersonId : 1000063
Standard representation of manufacturing capability information is a necessity for efficient configuration of loosely-coupled supply chains. ManuTerms is a formal thesaurus that provides a set of standard vocabulary that can be used for description of manufacturing capabilities. In this paper, a method is proposed for supplier characterization and classification guided by ManuTerms. The tools developed in this work use the capability narrative of manufacturing suppliers as the input and extract key concepts that refer to certain aspects of manufacturing capabilities in order to characterize and classify manufacturing suppliers. Through an experimental study, the supplier classification method was validated with respect to the level of agreement with human judgment.
978-3-642-41266-0_42_Chapter.pdf (390.78 Ko) Télécharger le fichier
hal-01452305 , version 1 (01-02-2017)
Paternité
Farhad Ameri, Stan Thornhill. Manufacturing Capability Inference and Supplier Classification Based on a Formal Thesaurus. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.344-351, ⟨10.1007/978-3-642-41266-0_42⟩. ⟨hal-01452305⟩
253 Consultations
468 Téléchargements
