Inverse Optimal Control Problem: the Sub-Riemannian Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IFAC-PapersOnLine Année : 2017
Frédéric Jean
Igor Zelenko
  • Fonction : Auteur
  • PersonId : 1000091
The object of this paper is to study the uniqueness of solutions of inverse control problems in the case where the dynamics is given by a control-affine system without drift and the costs are length and energy functionals.
inverseSR_short.pdf (279.77 Ko) Télécharger le fichier
hal-01452458 , version 1 (01-02-2017)
Frédéric Jean, Sofya Maslovskaya, Igor Zelenko. Inverse Optimal Control Problem: the Sub-Riemannian Case. IFAC-PapersOnLine, 2017, 50 (1), ⟨10.1016/j.ifacol.2017.08.105⟩. ⟨hal-01452458⟩
295 Consultations
261 Téléchargements
