Bringing Relevance to Computing Courses through History - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
John Impagliazzo
  • Fonction : Auteur
  • PersonId : 1000247
Mohammed Samaka
  • Fonction : Auteur
  • PersonId : 1000248
This paper shows ways in which computing history can make the delivery of teaching computing courses relevant. The authors’ approach involves using computing history as a recurring theme throughout courses by adapting relevant historical stories or material to enhance course delivery and to capture student interest. The use of computing history often makes a positive and constructive improvement in courses by making them more interesting, stimulating, and thereby, informing students with non-technical elements in their computing specialties. This approach to computing studies should prove to be a helpful addition to student studies and provide them with a stronger understanding of the computing field in their careers.
978-3-642-41650-7_13_Chapter.pdf (251.34 Ko) Télécharger le fichier
hal-01455247 , version 1 (03-02-2017)
Paternité
John Impagliazzo, Mohammed Samaka. Bringing Relevance to Computing Courses through History. International Conference on History of Computing (HC), Jun 2013, London, United Kingdom. pp.135-143, ⟨10.1007/978-3-642-41650-7_13⟩. ⟨hal-01455247⟩
66 Consultations
85 Téléchargements
