Multi-scale Robust Modelling of Landslide Susceptibility: Regional Rapid Assessment and Catchment Robust Fuzzy Ensemble - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Landslide susceptibility assessment is a fundamental component of effective landslide prevention. One of the main challenges in landslides forecasting is the assessment of spatial distribution of landslide susceptibility. Despite the many different approaches, landslide susceptibility assessment still remains a challenge. A semi-quantitative method is proposed combining heuristic, deterministic and probabilistic approaches for a robust catchment scale assessment. A fuzzy ensemble model has been exploited for aggregating an array of different susceptibility zonation maps. Each susceptibility zonation has been obtained by applying heterogeneous statistical techniques as logistic regression (LR), relative distance similarity (RDS), artificial neural network (ANN) and two different landslide susceptibility techniques based on the infinite slope stability model. The sequence of data-transformation models has been enhanced following the semantic array programming paradigm. The ensemble has been applied to a study area in Italy. This catchment scale methodology may be exploited for analysing the potential impact of landscape disturbances. At regional scale, a qualitative approach is also proposed as a rapid assessment technique – suitable for application in real-time operations such as wildfire emergency management.
978-3-642-41151-9_31_Chapter.pdf (2.9 Mo) Télécharger le fichier
hal-01457463 , version 1 (06-02-2017)
Paternité
Claudio Bosco, Daniele De Rigo, Tom Dijkstra, Graham Sander, Janusz Wasowski. Multi-scale Robust Modelling of Landslide Susceptibility: Regional Rapid Assessment and Catchment Robust Fuzzy Ensemble. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.321-335, ⟨10.1007/978-3-642-41151-9_31⟩. ⟨hal-01457463⟩
177 Consultations
102 Téléchargements
