Novel Approaches for Web-Based Access to Climate Change Adaptation Information – MEDIATION Adaptation Platform and ci:grasp-2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Markus Wrobel
  • Fonction : Auteur
  • PersonId : 1000471
Alexander Bisaro
  • Fonction : Auteur
  • PersonId : 1000472
Dominik Reusser
  • Fonction : Auteur
  • PersonId : 1000473
This paper presents two novel web-based applications for disseminating climate change adaptation related information. (i) The MEDIATION Adaptation Platform, one of the core outputs of the European FP7 research project MEDIATION (Methodology for Effective Decision-making on Impacts and AdaptaTION), offers a set of decision trees that can be browsed graphically to navigate over adaptation challenges and available types of methods for addressing them. This framework is interlinked both with a Toolbox and a set of case study descriptions. (ii) ci:grasp-2, the successor of the BMU-funded Climate Impacts: Global and Regional Adaptation Support Platform (ci:grasp), provides access to a growing pool of global and regional information on climate stimuli and impacts, as well as on adaptation projects. The paper identifies central user tasks for both applications and presents interaction metaphors that have been chosen to support users in fulfilling these tasks.
978-3-642-41151-9_45_Chapter.pdf (1.38 Mo) Télécharger le fichier
hal-01457479 , version 1 (06-02-2017)
Paternité
Markus Wrobel, Alexander Bisaro, Dominik Reusser, Jürgen P. Kropp. Novel Approaches for Web-Based Access to Climate Change Adaptation Information – MEDIATION Adaptation Platform and ci:grasp-2. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.489-499, ⟨10.1007/978-3-642-41151-9_45⟩. ⟨hal-01457479⟩
241 Consultations
90 Téléchargements
