Integration of Macro and Micro Sustainability Issues: The Need for ‘Engineering Accounting’ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joanne L. Tingey-Holyoak
  • Fonction : Auteur
  • PersonId : 1000475
Roger L. Burritt
  • Fonction : Auteur
  • PersonId : 1000476
John D. Pisaniello
  • Fonction : Auteur
  • PersonId : 1000477
The paper argues for the integration of engineering and accounting professionals through a transdisciplinary approach to on-farm water issues associated with farm dams. An integrated macro and micro solution is put forward in the context of poor farmer behaviour as spillways are blocked to pursue individual aims at the expense of other stakeholders, including downstream communities and the environment. Integrated engineering accounting is proposed as a solution through transdisciplinary thinking.
978-3-642-41151-9_46_Chapter.pdf (478.98 Ko) Télécharger le fichier
hal-01457480 , version 1 (06-02-2017)
Paternité
Joanne L. Tingey-Holyoak, Roger L. Burritt, John D. Pisaniello. Integration of Macro and Micro Sustainability Issues: The Need for ‘Engineering Accounting’. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.500-507, ⟨10.1007/978-3-642-41151-9_46⟩. ⟨hal-01457480⟩
156 Consultations
269 Téléchargements
