Intelligent Facility Management for Sustainability and Risk Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Adam Kučera
  • Fonction : Auteur
  • PersonId : 998661
Tomáš Pitner
  • Fonction : Auteur
  • PersonId : 983302
Building construction has gone through substantial change with the emerging spread of ICT during last decades. In the field of construction industry, the term intelligent buildings describes facilities equipped with devices and systems that can be remotely controlled and programmed and that are able to communicate and collaborate in order to ensure convenient building environment and effective operation. However, installing devices with such capabilities is only one part of the task of effective facility management and risk management. Facility managers have to be provided with tools that allow them to inspect and analyze gathered building operational data and make decisions to improve building performance. Decision support tools for facility managers usually lack deep integration with building systems. This article aims on technical aspects of providing data from intelligent buildings to the responsible personnel in order to help them to operate the building effectively with emphasis on its energy consumption and risk management.
978-3-642-41151-9_57_Chapter.pdf (4.09 Mo) Télécharger le fichier
hal-01457491 , version 1 (06-02-2017)
Paternité
Adam Kučera, Tomáš Pitner. Intelligent Facility Management for Sustainability and Risk Management. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.608-617, ⟨10.1007/978-3-642-41151-9_57⟩. ⟨hal-01457491⟩
118 Consultations
131 Téléchargements
