Local erosion rates versus active tectonics: cosmic ray exposure modelling in Provence (south-east France) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Earth and Planetary Science Letters Année : 2004
Emmanuel Baroux
  • Fonction : Auteur
Over the past decade, in situ-produced cosmogenic nuclides have revolutionised the study of landscape evolution. In particular, numerous studies have demonstrated that, in active tectonic settings, cosmic ray exposure dating of deformed or displaced geomorphic features makes it possible to quantify long-term deformation rates. In western European countries, erosion due to climatically driven processes and human activities is probably the factor that most limits the accuracy of exposure ages and landscape modification rates. In this study, we present the results of a depth-profiling technique applied to alluvial terraces located along the Rhône and the Moyenne Durance rivers. The expected decrease with depth of the measured 10Be concentrations has been modelled using a χ2 inversion method in order to constrain the exposure history of the alluvial sediments. The results suggest that: (1) over the Quaternary, the local surface erosion rates including both regional uplift and climatically driven processes acting on landforms are on the order of 30 m/Myr in southeastern France, and (2) providing a fairly good bracketing of the exposure age, the modelled abandonment age of alluvial terraces affected by the Moyenne Durance Fault allows estimating incision rates, comparing the alluvial terrace elevations with topographic river profiles, and a minimum vertical slip rate value of roughly 0.02 mm/yr for the southern segment of the Moyenne Durance Fault.
EPSL2004_accepted.pdf (31.3 Mo) Télécharger le fichier
hal-01457872 , version 1 (25-03-2019)
Lionel Siame, Olivier Bellier, Regis Braucher, Michel Sébrier, Edward Marc Cushing, et al.. Local erosion rates versus active tectonics: cosmic ray exposure modelling in Provence (south-east France). Earth and Planetary Science Letters, 2004, 220 (3-4), pp.345-364. ⟨10.1016/S0012-821X(04)00061-5⟩. ⟨hal-01457872⟩
450 Consultations
87 Téléchargements
