Self-assembly of tricuprous double helicates: Thermodynamics, kinetics, and mechanism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Helvetica Chimica Acta Année : 2001
We report in this paper the coordination and kinetic properties of two oligobipyridine strands, which contain three 2,2′-bipyridine subunits separated by oxydimethylene bridges, the 4,4′-bis(CONET2)-substituted L and the 4,4′-bis(CO2Et)-substituted L′. Spectrophotometric measurements allowed the characterization of thermodynamic complexes and kinetic intermediates* which are involved in the self-assembly process of L2Cu3 and L2Cu3 helicates. The reaction presents positive cooperativity for the binding of two 2,2′-bipyridine strands to the cuprous cations. While reactive kinetic intermediates* present distorted coordination geometries around Cu1, the final rearrangement of the tricuprous bistranded helicates allows more closely tetrahedral coordination of each cation and reduces the interactions. Differences in the bulkiness and electronic properties of the L and L′ substituents do not affect significantly the stability of the corresponding helicates, but greatly influence binding rates in the self-assembly process.
Chimie
Fatin Rouge_ Helvetica Chimica Acta 2001_auteur.pdf (3.01 Mo) Télécharger le fichier
Fatin Rouge_ Helvetica Chimica Acta 2001_SI_auteur.pdf (212.73 Ko) Télécharger le fichier
hal-01458136 , version 1 (25-04-2024)
N. Fatin-Rouge, Sylvie Blanc, A. Pfeil, A. Rigault, A.-M. Albrecht-Gary, et al.. Self-assembly of tricuprous double helicates: Thermodynamics, kinetics, and mechanism. Helvetica Chimica Acta, 2001, 84 (6), pp.1694-1711. ⟨10.1002/1522-2675(20010613)84:6<1694::AID-HLCA1694>3.0.CO;2-T⟩. ⟨hal-01458136⟩
61 Consultations
0 Téléchargements
