PyCP: An Open-Source Conformal Predictions Toolkit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vineeth N. Balasubramanian
  • Fonction : Auteur
  • PersonId : 1000629
Aaron Baker
  • Fonction : Auteur
  • PersonId : 1000630
Matthew Yanez
  • Fonction : Auteur
  • PersonId : 1000631
Shayok Chakraborty
  • Fonction : Auteur
  • PersonId : 1000632
Sethuraman Panchanathan
  • Fonction : Auteur
  • PersonId : 1000633
The Conformal Predictions framework is a new game-theoretic approach to reliable machine learning, which provides a methodology to obtain error calibration under classification and regression settings. The framework combines principles of transductive inference, algorithmic randomness and hypothesis testing to provide guaranteed error calibration in online settings (and calibration in offline settings supported by empirical studies). As the framework is being increasingly used in a variety of machine learning settings such as active learning, anomaly detection, feature selection, and change detection, there is a need to develop algorithmic implementations of the framework that can be used and further improved by researchers and practitioners. In this paper, we introduce PyCP, an open-source implementation of the Conformal Predictions framework that currently provides support for classification problems within transductive and Mondrian settings. PyCP is modular, extensible and intended for community sharing and development.
978-3-642-41142-7_37_Chapter.pdf (629.91 Ko) Télécharger le fichier
hal-01459631 , version 1 (07-02-2017)
Paternité
Vineeth N. Balasubramanian, Aaron Baker, Matthew Yanez, Shayok Chakraborty, Sethuraman Panchanathan. PyCP: An Open-Source Conformal Predictions Toolkit. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.361-370, ⟨10.1007/978-3-642-41142-7_37⟩. ⟨hal-01459631⟩
144 Consultations
890 Téléchargements
