Learning by Conformal Predictors with Additional Information
In many supervised learning applications, the existence of additional information in training data is very common. Recently, Vapnik introduced a new method called LUPI which provides a learning paradigm under privileged (or additional) information. It describes the SVM+ technique to process this information in batch mode. Following this method, we apply the approach to deal with additional information by conformal predictors. An application to a medical diagnostic problem is considered and the results are reported.
Informatique [cs]
