Local Clustering Conformal Predictor for Imbalanced Data Classification - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Huazhen Wang
  • Function : Author
Yewang Chen
  • Function : Author
Zhigang Chen
  • Function : Author
Fan Yang
  • Function : Author
The recently developed Conformal Predictor (CP) can provide calibrated confidence for prediction which is out of the traditional predictors’ capacity. However, CP works for balanced data and fails in the case of imbalanced data. To handle this problem, Local Clustering Conformal Predictor (LCCP) which plugs a two-level partition into the framework of CP is proposed. In the first-level partition, the whole imbalanced training dataset is partitioned into some class-taxonomy data subsets. Secondly, the majority class examples proceed to be partitioned into some cluster-taxonomy data subsets by clustering method. To predict a new instance, LCCP selects the nearest cluster, incorporated with the minority class examples, to build a re-balanced training data. The designed LCCP model aims to not only provide valid confidence for prediction, but significantly improve the prediction efficiency as well. The experimental results show that LCCP model presents superiority than CP model for imbalanced data classification.
978-3-642-41142-7_43_Chapter.pdf (376.12 Ko) Télécharger le fichier
Dates and versions
hal-01459637 , version 1 (07-02-2017)
Attribution
Identifiers
Cite
Huazhen Wang, Yewang Chen, Zhigang Chen, Fan Yang. Local Clustering Conformal Predictor for Imbalanced Data Classification. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.421-431, ⟨10.1007/978-3-642-41142-7_43⟩. ⟨hal-01459637⟩
227 View
146 Download
Share
